How to Fix Payment Integration Issues in XOXO Clone Script?
If you're facing payment integration issues in your XOXO MLM, the problem is usually related to incorrect API configuration, unsupported payment gateways, SSL certificate errors, or webhook misconfiguration. First, verify that your payment gateway API keys (Live/Test) are correctly configured in the admin panel and match the selected environment. Ensure your server has a valid SSL certificate, as most gateways require HTTPS for secure transactions. Check webhook URLs and confirm they are properly connected to receive payment status updates. Also, review server logs to identify timeout issues, currency mismatches, or callback failures. Updating the gateway plugin, clearing cache, and testing transactions in sandbox mode can help isolate the issue. If problems persist, consult your payment provider’s documentation and ensure your XOXO Clone Script version is fully compatible with the selected payment gateway.
